The 79...
  • #91
    Been a while...
    Rewired this Landcruiser with an LS for a fellow Firefighter.
    Did door seals and now doing the front carpet kit...
    Timing set R & R after the carpet
    Ordered the last of the AC components today, so AC will hopefully be in-service this Summer.
    • #92
      A year later I got the front half of the carpet kit in.... Time for timing gears. (Well I had a video of the gear/chain slop, but but it says I'm not authorized to download it here) Let's just say I maxed out the life expectancy of the Factory Ford Aluminum cam gear with the nylon teeth at 92+K miles.
      Sent my Harmonic balancer off to Damper Dudes to be rebuilt, it is challenging at times to find parts for the Yellow Sub. Already experienced Off-shore parts failures, Sad. (Fuel pump at 900 miles and Electronic voltage Reg at 1,200.)
      Another anniversary of Mark Beck's passing, I believe it has been 13 years now. (he was a Salesman for Wild Horses)
      • #93
        As you know I've experienced my share of early parts failures (several that were no good right out of the box). It's disheartening, and part of the reason I don't really venture too far in my rig anymore. How big of a box of spares is practical to carry? sigh... already carry an alternator when I go farther than say 30 miles, among other things.
        Ordering from WH has not been the same since Mark's passing. I can still hear him say: "That'll be $100 plus $9 for Gov. Schwarzenegger"
        • #94
          Almost forgot Mark's colorful commentary when making a Sale...
          You can't let the fear of things taking a "Chit" stop you from adventuring out into the world Tony. People out there would kill to have a Bronco like yours. I agree that it is disappointing to have failures and how much is made off-shore now. (Not just with car parts) And the added cost of something made in the USA. At least we can fix it ourselves and not have to pay someone to do it.
          • #95
            I agree with you, and I may have overstated my "range" concerns - but having come home on the back of a tow truck 5 or 6 times... it gets to me. The worst example was the wheel bearing failure which nearly resulted in a wheel coming off at speed on the highway. Had there been an oncoming vehicle in the other lane... I know that I would not be here typing this today (not to mention, the ex's kids would not have had a mother)... I will probably never fully get past that experience, but I digress. I like the way that Yellow Sub is coming along, it's a nice rig!
            • #96
              Timing Gears done, had to drop the oil pan
              New motor mounts made dropping the pan a bitch... They have been modified now.
              Damper dudes came through with a rebuilt HB.
              New oil pan drain plug leaked, sooo on the rack it went and it looks like a Dorman steel gasket embossed with rubber fixed than.
              AC components have been reinstalled, evac and refill with R134A scheduled for Wednesday. (Thanks Karl for the AC advise)
              Mixed bag on the company in Florida who provided the AC upgrade, 3 weeks to get product, poor communication, I made calls. One of their brackets did not fit, called, a day and a half later with no return call, I made my own bracket.
              Working on installing a Cruise control. Had a new Speedo cable made with provisions for a Ford VSS so I have a signal rather than mounting magnets on on the driveshaft with a pickup nearby.
              Planning a Road trip to Idaho in May
              • #97
                I’m looking forward to see how your A/C system works.
                • #98
                  Got in a day early at the AC shop yesterday... I have cold air now.
                  Cruise Control and new Captain's chairs showed up yesterday, Hopefully I can get both installed in the next few days. Pictures later......
                  • #99
                    Rostra Cruise Control worked twice and hasn't since. (Deep cleansing exhale) Did electrical connection checks yesterday and will put it in Troubleshoot mode today and see "if its Needs are being met"?
                    I had a new speedo cable made that is set up for a Ford type VSS that goes into the NP205. Changed the drive gear and now have the speedo reading within 2 mph of the correct speed based on GPS. Wondering to myself if this new VSS took a dump already, some recent experiences with new parts have lowered my expectations... I need the pulse generation for the CC.
                    Got the Drivers seat installed, apparently Captains chairs need a "wedge" installed where my low backs do not. It was a factory part which is impossible to find. The seat manufacturer is having them re-popped, but has none in stock at the moment. So one of my Fab buddies built me a set. It is amazing the things you can do on a Bridgeport mill. I will just run with one new seat for now. So nice not sitting on the springs anymore...
                    • Well went through all the connections, tested that I had a Tach signal, and found that I have a weak fuse holder in the factory panel. Even took EFI Guy's advice on how to test the VSS. Yes, I did have a signal all the way to the connection point to the CC. I didn't really find anything wrong? I went out for a test drive and the thing works flawlessly now. Don't know what I did, but I will take it.
                      Bumped the timing a few degrees, filled the tank (Ouch $$$), and off to Idaho I go...
                      Oh, did I mention that I am a Painter now...
                      • Driving the bronco to Idaho? Drive safe.
                        • Originally posted by onpier55 View Post
                          I am...
                          • Safe travels Doug. Enjoy the Sub. It really looks amazing.
                            • I know that drive well... too well. 80 to Winnemucca, 95 north through lovely towns such as Orovada, Rome, and Jordan Valley. I don't have many family members up there anymore so I doubt I'll have the pleasure of doing that drive again. The most frequent vehicle we took through there was my dad's old K5. So... you're somewhat replicating my childhood summer trips. Safe travels!
