Thanks Doug. Good information.
“Blue” 69
Was able to do some trouble shooting on my backfire issue and P0174 lean bank 2 code with the help of one of the mechanics at work. Eliminated vacuum leaks with a smoke test. No exhaust leaks. Timing looks correct. Scanner shows the long tern fuel trim for bank 2 is maxed out at 30 and doesn't change. New O2 sensors that look to be working fine on the scanner. Computer appears to be compensating for what it sees as a lean condition for bank 2 however bank 2 appears to be extremely rich. Exhaust has fuel smell which would go along with the backfire I am hearing. Pulled a plug and it is rich on bank 2 and looks perfect on bank 1. Not sure where to go from here. Mechanic thinks it may be a programing issue or something to do with the downstream O2 sensor delete so I sent EFI an email and will see what he suggests. Anyone have any other thoughts on what to check next. Thanks.
Update: Garry (EFI Guy) did reply to my email this morning (didn’t expect that quick of a reply, thank you Garry) with a few things to check out regarding O2 sensor wiring etc. Will try and check those out tonight.Last edited by M_luther; 04-15-2021, 08:58 AM.
Been about five weeks since my last post. Finally think I got the issue solve. Seems to have been a poor fitting plug wire on cylinder 5 caused by minimal clearance on my modified drivers side stock exhaust manifold. Installed a set of ceramic coated Bronco Hut shorty headers. They fit perfectly and provide great plug clearance for my gt40p heads. Couldn’t be happier with them. Picked up my Bronco from exhaust today after having the head pipes redone. Problem solved. Went for a 50 mile drive after work and it is now a running great. Will put some more miles on and see if any other issues surface. Had to do an egr delete with the header install which allowed me to remove the 90deg elbow behind the throttle body. This fixed my TPS hood clearance issue which was a plus.
Garry is a great guy, very knowledgeable and willing to help. I am going to put some more miles on this weekend to make sure I don’t have any issues to correct before I charge up the AC. I also ordered some heat sleeve for one of my AC hoses that is a little closer to the header than I like. I think it would be fine without it, but I will feel better if it has a little heat protection. Other than charging the AC is completed. The heater side of the Vintage system works good though.Last edited by M_luther; 05-21-2021, 01:59 PM.
