Cant wait to get my new issue of Crawl in the mailbox!!! Whats that make of NCB members, #2 to get in there? First it was Patrick now Welndmn, I beleive?
Mark's 71 BKO
Yep, looking good...those might be my next tires, but at the rate I'm going and use of my rig...mabey something better will be out there a decade or so from now.
I know my brother's eb is hella tall and I wasn't sure if I was to tall or even accomplished lowering mine down a bit so I measured mine.
54" to the fender on 39.5" tsls.... that makes me feel better.
Whats your belly height, I may have lost clearance there for the over all height of the rig. I'm sitting at 23 1/4" at the lowest point of the skid.70 eb 60f 14b mild 302 435-klune 4-1-np205 and some dents
Originally posted by bent70Yep, looking good...those might be my next tires, but at the rate I'm going and use of my rig...mabey something better will be out there a decade or so from now.
Only way I can get lower is going to be narrowing the body.
No idea on my belly height though, it only about 1.5 below the frame.Mark Harris
Hey Mark, are you running stock Ford or Chevy knuckles? Have you ever had a problem?
Thanks FM <><72EB, one-ton fab project that will never end
Running Stock Ford kunckles on High steer
I have not had a problem and I have blew up 2 shafts in it.
The key to making them live is have limit stops.
I have stops on my ram and the factory stops. Ford kunckles seem to blow up when you loose an axle shaft, or bend/over turn your limit stops on the steering.
I do carry spare kunckles though. If I ever brake one, I'll get some Orange ones like Patricks.Mark Harris
Not much new here.
Tied my seats into my cage.
Plans on moving the rear links down a little to add more Anti-sqaut, because with the bigger tires, I felt it did not climb as good as it did. Bad news is I am out of adjustiabilty (sp?) so I have to re make the mount.
Also plan on redoing the entire exhaust as it would be in the way now.
Small pic from soup bowl over the weekend.Mark Harris
Is that boulder at your drivers rear corner new? Also what did you use for stops on your ram and do you have any pics?67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
Looks like a good reason for that rail protection.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
I made it up
But I did not make that. Once I got one tire up i was done. I had to do a front burn and bring it over to the passenger side
I feel with a little more Anti squat I should of been able to climb it because it wanted to sooooo bad. Could of also been because the tires are still to new. They are aired down to 4-5 PSI with no beadlocks and still don't flex the way I want them to.
For my ram, I used 2 inch derlin from McMaster car, then put a hole in it, and placed it over the shaft of the ram. I know some don't like the external stops, but I also did not want to take the ram apart.Mark Harris
Not much of an update.
I moved my rear upper links around to increase some of my Antisquat and lose some rear steer.
I was running 55% AS with 1% rear steer. I changed it to 80% AS, still having 1 % rear steer.
I jumped to 98% AS and 0% rear steer.
Lets just say and cut and ground and welded stuff a BUNCH of times.
Also in the process I got pissed off at my cobbled together exhaust system and ripped it all out.
Bought some 2 1/4 pre bent pipes, and some 2 1/2 pipes with a Y pipe to a single 3 inch muffler.
Also just got some block hugger headers they I plan to get on there and make fit better.
To fit the headers you have to have a mini starter. Well its about time I bought one anyway. 93 Ford F-150 with a stick and 302 was the app.
I installed, and love the way it sounds. Before the old moveable pole shoe starters always seemed to struggle to crank the engine over and this one does it effortless.
It was 98$ at Kragen with 3 year.Mark Harris
Going from 55% to 98% AS, aren't you decreasing the amount of AS that you have? 100% AS means that your rear has no AS upon acceleration, correct?Last edited by crawlin68; 08-21-2007, 09:40 AM.
