other way around.
The higher the AS number, the more the rear end stands up and pushes downward on the rear tires.
To high of number leads to bad hopping.
To low of number the rear squats down to the bump stops.
There is no magic number, I have seen from 20% to 190%.
Really you just play and move stuff around until you find where you like it.
Some moon buggies run insane low numbers so they squat down on the bumpstops and pin the gas to make a climb.
I dunno, I don't belive much of the math or theroys behind AS.
You just change your numbers to fit your driving style and rig.
I ran low numbers because mine is a few years old. Today I see many running from 80-110 and that seems to be the best area for a trail rig.
Figure I would try it, its only metal
