67 bronco
  • 67 bronco
    Picked up this bronco in October 2017. I’ve been tearing it apart to replace a floor panel. Now It’s stripped
    Down and off the frame. Now frame is on a rotisserie. It Came with a mercury marine 302 and 351w. Both need rebuilt. Was going to install a rebuilt 351w. Now I’m going with an explorer swap.
    Re: 67 bronco
    Welcome! That looks like a nice one to start with. This will be a great build to watch. What is your end goal? Stock, Luber, Wheeler? Where are you located? I'm looking forward to seeing your progress.
      Re: 67 bronco
      Welcome Karl,
      Amassing how one project morphs into a complete rebuild!
      Doug
        Re: 67 bronco
        Crawlin68. Right now I plan on an np435 for road and hunting. Not going lubr. Fenders are already cut. Original plan was use 351w that it came with. But I picked up an explorer motor. So I’m doing fuel injection. Already did my wiring harness and pcm is on its way back from efiguy. But as with broncos. Plans are always fluid. Lol.
          Re: 67 bronco
          Doug, Yes. The build seems to change daily. Haha. Back in October I would have never thought I would go with an explorer motor and full efi. I thought I wanted a plane Jane motor with carb or tbi. But after reading a million threads, I changed my mind once again. I also would have never thought that I would order a custom tank from aero thanks to you. And thanks for the email to offer the mass buy. And thanks for answering all my questions. Karl
            Re: 67 bronco
            Crawin68. I’m in the Sacramento area.
              Re: 67 bronco
              Nice starting point!
              What part? Im over in folsom.
                Re: 67 bronco
                I’m in roseville but I work on the bronco in northern highlands.
                  Re: 67 bronco
                  Removing the top.
                    Re: 67 bronco
                    Rusty floor pan. Soon to be replaced. Click image for larger version
ID:	275256Click image for larger version
                      Re: 67 bronco
                      Sounds like we are doing similar builds. I ended up buying an entire explorer for the donor 5.0/4R70W. I just ordered my fuel tank from Aero as well, should have it on the 15th or so.
                      75 Bronco - 5.0 EDIS/4R70W/44/9
                      68 Bronco - 6 cyl, 3 speed SOLD
                      71 Bronco - 302/NP435/44/9 ARB 4:88's 5.5 lift, 37 Toyos SOLD
                      70 Bronco - 1 tons/42's/ Coilovers f/r SOLD
                        Re: 67 bronco
                        Sorry we missed you on the mass buy Gebraic... Doug
                          Re: 67 bronco
                          New pan in place. Had to replace a small section that had rusted also. Click image for larger version
                            Re: 67 bronco
                            Drivers side floor pan repair. Click image for larger version
                              Re: 67 bronco
                              Passenger Click image for larger version
ID:	275259side apron replacement.
