The **OFFICIAL** 4th Annual "Broncos on the Con" June (23), 24 ,25 ,26 2011
Re: The **OFFICIAL** 4th Annual "Broncos on the Con" June (23), 24 ,25 ,26 2011
I guess I have a list too.
Rear bumps and 2 inch shorter shocks.
Shorter Shocks in front 3-4"
Re-route crossover exhaust pipe
Flip safety washers on steering and ram. Getting too much tie rod rotation.
Would like to install side rail and rear quarter protectors and actually paint them.
I have 6 months to get this done, but probably wont get too it. Ill get more body damage and probably use the long shocks as bump stops...
I know I will find more stuff to do to my Bronco before June - but hopefully just maintenance. I will probably add a winch and a second battery this spring. There's also a weird noise up front that I've never been able to find, but have logged plenty of trail miles with it clunking away, so maybe its just a normal Bronco noise. Its pretty minor, it just bugs me since I can't identify it. Doesn't seem to have any ill effects on drivability.
Shocks as bump stops = destruction!
Maybe it's the nut behind the wheel that is loose?
My list
Get the Bronco going
Wheel it before the Con tip
Hope I get the time off work.
