67 bronco
  • Re: 67 bronco
    For Explorer cable or a Mustang...
    I copied a bracket that I saw on a Full size mid -70's Ford at the wrecking yard that had two cables going to the accel pedal...
    Done this on numerous builds with great success.
    The important thing to do is try and keep the cable pulls as straight as possible at pedal arm. And then test that the movement of the cable as it moves the TB butterfly open to the full extent.
    You may have to bend the arm of the pedal assembly some to get WOT or to limit the possibility of snapping the cable...
    As I have been finding out lately... Explorer 5.0L have been out of production for 17 years and some things are obsolete now.
ID:	275846Click image for larger version
ID:	275847Click image for larger version
    Mustang cable:
ID:	275849Click image for larger version
    Had to go out and take this picture:
Name:	Accel Bracket measurements.jpg
    • Re: 67 bronco
      Thank you Doug!
      I did get the cable out of the Mountaineer. I had read that it was needed before I pulled the motor.
      Thanks
      Karl
      • Re: 67 bronco
        A little paint on the needles. Found this paint at Hobby Lobby. Freshened right up after 51 years.
        • Re: 67 bronco
          Ordered a smooth collar off of classic Broncos. Arrived today. Another piece to the puzzle. Getting rid of the nub from the shifter. Things are going back together.
          • Re: 67 bronco
            Steering column is rebuilt with new bearings and the smooth shift collar. It’s going in this weekend. Things are coming together nicely
            • Re: 67 bronco
              Looking good man! Keep up the good work and you'll be driving your Bronco before you know it.
              • Re: 67 bronco
                Thanks, Man. I’m in the home stretch. I hope.
                • Re: 67 bronco
                  Work in progress. Dash and electrical. Speedometer back together.
                  • Re: 67 bronco
                    Hey Don't use wire nuts...
                    • Re: 67 bronco
                      I’m not. Just using to hold wires together til I get everything situated, to length and in place. Then solder and heat shrink.
                      • Re: 67 bronco
                        Well then... My apologizes...
                        The build is moving along well then... Wish I could say the same. A little bit each day as they say...
                        • Re: 67 bronco
                          Yes. A little bit everyday. I don’t think I’ve had more than six hours straight to work on it in a day. Mostly an hour here and there. Baby steps. My first build, so I want to measure twice and solder once (LoL) and make it look as clean as possible.
                          • Re: 67 bronco
                            Picked up a check engine light from Tognottis today.
                            • Re: 67 bronco
                              Been working on the wiring the last two weeks. Today was able to check my relay operation on the harness that I made from watching the efiguy video. I thought I screwed up somehow. But after tracing out the wiring. Found that I did not have the ground hooked up that goes to the relays. Lol. Oops. Seems to work great. Next up. Welding the Mounts to the fuel tank and wiring up the fuel pump and fuel level sending unit.pic for attention. Lol.
                              • Re: 67 bronco
                                Still working on the electrical. I don’t like the fuse block that I used. I bought it when I made the harness to be able to get he harness done. Any recommendations on fuse blocks to feed the relays.
                                Thanks
                                Karl
