I’ve been piecing together ac parts. Installing it now. Made the hoses from parts from summit and Tognottis. Borrowed a crimper to make hoses from a fellow bronco buddy. Pulled a vacuum on the system and put in a holding charge tonight. Probably won’t get it finished before archery season starts on Saturday but excited to get a little cold air blowing. Sacramento area gets a little hot. Haha
After piecing all the parts for a/c, spending many nights working on it, while in the middle of installing my solar at the same time, but that’s a story for another time. It was a success. I did cut the dash to make my life easier. Here are the results. Took the maden voyage at ten pm last night. I’m am real happy with the results. It got chilly in the cab. Also I talked to Garry about my pcm and an intermittent stall while coming up to a stop sign. He asked if I was running a Vss. I wasn’t because I have a four speed. He recommended installing on. I installed it while I had the dash apart. Luckily I didn’t de-pin that wire from the wiring harness. No more intermittent stall. Sweet success.
