Welp. Another leak. I’m going to need to change the intake manifold. Can I use any intake from a 96-2001 explorer motor? Mine is a 99 Mountaineer motor.
Thanks
Karl
I won’t do that again. I was out in Fairfield on a job and went to the Fairfield pick and pull. Pulled an intake manifold out of a 96. It’s always nice when somebody loosens everything up but doesn’t know about the two bolts under the 5.0 plaque. So if I get home early enough today I will be installing it. After I tap and plug the EGR plug for the 96 manifold.
After searching around. Found the plug at O’Reilly. Male pipe thread tap was at Ace hardware. What thread sealer should I use? Doug, I didn’t see your post til now. I’ll grab extra parts on next visit. Right now this Refrigeration guy is working 12 hours days on a slow day. $$$
Thanks
Karl
Well, I removed the intake manifold. Only problem I ran into was the front passenger bolt broke off in my motor. Same issue happened at pNp in the donor motor. Must be a common issue. I’ll get it out. Tomorrow and tap it. The fun continues. Haha!
More fun. Broken chinesium tap broke off in the head. Another bronco buddy, who is a mechanic, has a remover that’ll cut thru it like butter. His words. Hopefully back together by this weekend.
I was able to get the tap out. That bronco buddies tool did not cut thru it mike butter as advertised. I was able to use a torch a hundred time to make lava out of it and slowly chisel it out. I’m a happy camper.
