Re: Explorer serp setups?
Keep in mind that the Van bracket is designed for kind of an oddball AC compressor. I tried to mount a York compressor to it, and it wouldn't have been that hard but I don't have the hood clearance for it. I simply couldn't get the York low enough on the bracket to allow the hood to close and have the York not interfering with other stuff under hood. You have two advantages though - a taller hood and a shorter motor.
I adapted a Sanden to mine and did the "grease mod" which seems to work pretty well. Just a little food for thought. The only thing I don't like about the van bracket is that it puts the PS pump pretty low and the bracket rides pretty close to the frame. I notched my bracket to allow for clearance. Again with a 302-based block it probably won't be an issue.
