Well I went to P.C. today to have some fun with my son and nephew. We had hit about everything P.C. had when we drove around and found this nice little uphill climb. You know the sort - kinda steep to a ledge about 3' high to get to the top. So try it slow , then try it medium and then floor it Well after the front end left the ground and possibly the rear it bounced landed and then -BOOM
Thought I just bent a leaf spring and broke the rear driveline yoke but no it gets better. I thought "man that anti-wrap bar I built sucks. but then I noticed the pinion angle about 10 degrees further north
Yep, the axle wrap bar held the axle in place just like I built it. BUT it did not hold the center section from rotating. So if I haven't descibed it well the axle tube accual rotated in the center section anout an inch or 10 degrees. Now my question - how do I fix it or do I need to buy a new axle and place all my goodies in it???
In the pictures look at the center section you will see empty holes on the drv side center section and filled ones on the psg side - yea, not good I know???
Thanks for the imput - hey good news is my antiwrap works great if I can keep the axle together
