My Dana 20 finally gave up on me on a recent trailride It was not pretty. Anyway it is a good time to upgrade, right? I thought about just rebuilding the 20 but by the time it is built right I could buy an Atlas and be done with it. The Atlas will not bolt up to the three speed, so I needed a tranny too.
I had been looking for a ZF for while as I wanted to keep a manual trans and needed a low first gear. The ZF seemed like the perfect tranny. After a long search in the local junkyards I found a ZF for $500. It was out of the truck so I have no idea how many miles are on the thing. But, I spent so much time looking for one, I am giving it a go.
I ordered all the ZF stuff (clutch, cross member and hydraulic system) from BC Broncos, excellent people!
I have never swapped a tranny or transfer case before but am fairly mechanical and have some friends that are smarter than me.
So I figured I would document the build along the way, maybe it will help someone, I am sure I will have some questions!
Day 1:
I chose to modify the clutch pedal first. I had to remove the pedal from the truck to drill the needed hole. The clutch and brake pedals rotate on a common shaft behind the dash. It must be removed from the driver's side.
There are small retaining clips on each end of the shaft. I first removed these and removed the shaft using a hammer from the passenger side. The brake pedal, clutch pedal, shaft and a sleeve all came out. I took the pedal over to the vise and clamped it down. I measured down from the top 4.5" and center punched it.
Using various size bits, I worked my way up to 3/8”.
Now everything can go back in. I started with the brake pedal. I set in position, attached to the MC pushrod and put a spare bolt to hold it (from the passenger side). The bolt was long enough to hold the sleeve roughly in place as well. The shaft must go in from the driver’s side as it is “keyed” to fit one way. Holding the clutch pedal in one hand, start the shaft in the bracket, through the pedal, and into the sleeve. Keep sliding the shaft until the last bracket, towards the passenger side.
This where it gets tricky. The shaft has a flat spot cut into it that must line up with the bracket. Keep rotating the shaft until it lines up and goes through the bracket, install new cotter pins.
The attached pic is of the clutch pedal from the driver's side. I had not yet drilled the hole yet.
The second pic is the modified pedal.
Feel free to comment, give advice, etc, etc.
Mark
Day 1:
Mark
