I have a 96 explorer motor being rebuilt right now. I plan on converting over to 88-93 mustang stuff.
1. Has anyone had good luck with a reman A9L ECU equivalent from your local parts store?
2.Can I use my stock explorer MAF housing and change the MAF sensor? Or should I just buy a whole new MAF sensor for the mustang? The explorer MAF has a different plug that's a 6-wire
3. I plan on fabricating my own stainless fuel tank. I have the factory explorer bolt flange and I can buy a whole new sending unit/pump/sock for about 200 bucks. Has anyone else done this before? I work in a large sheet metal shop with endless stainless scrap.
4. I found a good BP sensor at pick n pull. Should I even use it or should I buy ALL new sensors?
5. The stock explorer intake tube has a convenient location for the ACT between the MAF and throttle body. Should I still drill and tap my explorer lower since that's where the mustang ACT was located?
Thanks for the help!
