Re: Death Wobble Re Visited
OK, my turn.
I have some years of experience with the afore-mentioned death wobble. Let me assure you that it is NOT an Chrysler / Jeep issue. It is an issue with any live axle front suspension.
I have experienced death wobble in a 1946 Willys CJ-2A. Not a shimmy, or a shake. Death wobble, like tires moving 8-10 inches side to side. Ugly, scary, like the videos death wobble. Also had it on a 67 Bronco.
Death wobble does not have a specific "cause." Anyone that tells you otherwise is mis-informed. Death wobble is the convergence of four things that must come together to result in the wobble.
***Important to remeber. Correlation is NOT causation. This means that just because two things are correlated, it does not mean that one causes the other. Just like "speed kills." Accidents are correlated to speed. But you would not argue that accidents CAUSE speeding. It is equally INCORRECT to assume that speeding causes accidents. (because we know that you can successfully speed without having an accident...)
With that in mind, you need four key things to invoke death wobble.
1. Some compliance in the lateral location of the front axle. A loose trac-bar, a loose mount, bad shocks, soft leaf springs, etc.
2. Low centering force in the tires. (yes, I'm blaming the tires...)
3. Some kind of initiator to begin the oscillation. A bump, a shimmy, a tire out of balance, or out of round, something.
4. Low centering force in the steering geometry.
...and lateral drag links.
Death woble is the product of these four components. And this is why people will tell you that they can cure death wobble by changing item 1,2,3 or 4. ...and why people will tell you that they have exactly the same "thing" and do not have death wobble.
For example, lets start with Caster. That goes under item 4. Some people tell you that if you have 5-7 degrees of positive caster...you will not get death wobble. But if you have lots of problems with item 1,2, and 3...you can still get DW. On the other hand, there are examples of vehicles with 1 degree of caster that have never seen DW.
(aside...I have never heard of DW on cars with fore-aft drag links. That includes Toyota Hilux, and every GM, and Dodge 4x4 with leaf springs. This is an observation, but an important one. The ability to control DW is correlated to the tie rod / drag link geometry.)
With that, if you want to eliminate Death Wobble in your Bronco, ensure that the front steering / trac bar is not worn. Ensure that you have 7 degrees of caster. Ensure that you are using <33 inch round and balanced BFG radial mud terrain T/A's with <.006 inches of indicated runout.
Then tell me if you bronco still wobbles...Mine will run with 5 inches of lift, up to 80 mph on any road...and no hands on the steering wheel.
BTW, my 2007 JK Rubicon does not wobble. Every JK that I've seen with DW is running OEM Goodyears. Those tires love to wobble...but a tight front suspension keeps it in check. As everything wears, the Jeep starts to wander. Then wobble...
OK, my turn.
