Update: I installed the rear brake delay device, which involved redoing my rear brake line. The new brake line flare tool that I bought works pretty nicely - I have no more leaks. I bled the system today and went for a test drive. Braking performance is still lackluster.
On a positive note: my bronco now stops totally straight with the rear brakes no longer locking up before the fronts. There is no hint of any sideways influence under full braking. The problem is that none of the brakes lock up now. I can definitely tell that the fronts are doing "something" but it appears they're not doing enough.
I went through the process of adjusting the proportioning valve all the way from least pressure to max pressure. I can tell that the rears are braking sooner at max pressure than they are at minimum pressure, so I know that the adjustable valve is doing its job.
I've decided to invest in a brake line pressure gauge. I remain convinced that my front brakes are (and always have been) the root of the problem. I don't think they are grabbing hard enough. As I may have mentioned earlier in this post, I replaced the front pads as one of my earlier steps in the process. I have also pulled the front calipers off and ensured that. the slide bolts are lubed. I have no doubt that the booster is doing its job; the pedal pressure required to "floor" the brakes is significantly lighter with the engine running than it is with out the assist.
When I receive the pressure gauge, I will do further investigations and see where this leads. This entire past week I was pretty occupied with work and after-work activities so I had very little opportunity to look at this in the evenings. This coming week looks better. Next weekend I have plans to take my nieces to an event (something I don't get to do enough of, so I am taking advantage of the rare opportunity). So it may be another couple of weeks before I make significant progress again.
If I continue to have problems, I'm going to start searching for a shop or an individual who can do further diagnostics. So if anybody reading this is able to come help me, you'll be compensated at minimum with a nice meal and some tasty beverages - or cash if that's what it takes.
It did feel good to fire up the bronco and cruise around the 'hood today even with the poor braking performance... I am motivated to fix this once and for all; these warm (but not hot) days are prime Bronco driving weather. I'd really like to load up with gear and go get lost for a few days in the rig, soon!
