I'm putting 11 leaf pack in this weekend. where can i get u-bolts to replace my old ones?? Any ideas??
best place to get u-bolts??
Not sure of the turn around time but I understand that Sac Spring company custom builds them, if you want 5/8" u-bolts. You would probably need some custom plates, but they would never fail. Or check out http://www.wildhorses4x4.com/33.asp look at their super duty U-bolt kit. Looks pretty nice.
I got the Sac Spring u-bolts but that was before the WH option. Good luck72EB, one-ton fab project that will never end
Originally posted by DennisIf your in Sac, then check out Hanley's Blacksmith and Spring Shop. 916-451-9126. He is almost right accross the street from where Bronco Parts used to be.“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
they weren't cheap 10 years ago when I bought mine either1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Originally posted by kwsponythey weren't cheap 10 years ago when I bought mine either
make sure dentoni's is giving you nuts and washers....they are shady that way...“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
