Ok guys I know most of you are into the EB but my project is a little newer. I have an 88 I believe stock everything except the K&N Air Filter. I found a set of 35" tires for $250 mounted on a 15" rim, which I am running as well. Do you guys think they'll fit? How much lift do you think I would need to get them under? I'm not afraid of cutting as well to get them to fit. I saw an article in Petersen's 4 wheel and off road magazine spot lighting a 1990 Bronco and I am looking to do something similar to that, it was Chris Bishop's rock Bronc. If you guys have any ideas on anything I can put under my truck tp make it trail ready and hopefully fit the 35's I have found.
Project 88
1971 EB: 3.5" 4 link rear, wristed front, 2" body, 96 Explorer 5.0 EDIS EEC-IV, C6, Nissan PS, Hydroboost w/front disks, 4.88 9" w/spool, D44 w/ aussie locker, TRO, 37" MTRs
Re: Project 88
Before you spend any $$ on a lift kit, seriously consider a sas. I had an 88 f150 with 35s and a 6" lift. I didn't wheel it but it would rub the rear of the fender going over a curb. Plus the front end allignment sucks ass.
-Darin67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
Re: Project 88
A Dana 44 out of a 78-79 bronco or any fullsize ford 1/2 ton pickup with a straight axle. You can PM Fullsize here as his is an 89 and he did the SAS. He could answer your questions. I think Sillyneck did the work. He would be another one to ask.Last edited by kwspony; 05-28-2009, 04:48 PM.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Re: Project 88
ok thanks. Hmmm a 78-79 huh?? Well that is pretty nice since my dad will be parting with his 79 this summer, it is a nice rig he just doesnt have the time for it.
I want to make my truck something not only I will be proud of but that other wheelers will be to when they see it. My neighbor and I are planning half doors, we think we have figured out how to keep the power to the doors just need to find a junk set and cut emm up. If any of you guys have any ideas to make this rig totally kick @$$ feel free to email me footballman95826@yahoo.com or message me on here I am up for all ideas.
Re: Project 88
Having owned both an 84 full size Bronco and a 79 Bronco, I would just wait till your dad gets rid of his 79 then grab it. I bought my 84 new, wheeled it allot but it was really a road rig and I loved it. After the sun finally rotted the interior and it burnt a valve, I sold it to pick and pull for $150.
I loved my 79 but decided to go EB only so I sold it for $3500. the 78-79 has a better frame to build from, will clear big tires easy, comes with a HP Dana 44 w/ discs, a good 9" rear end, and the interior won't rot out. Just my opinion.Relativity: Where ever you go, there you are.
Re: Project 88
x2 on the 79'67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
Re: Project 88
So let me make sure I am reading properly, you guys are saying if I wanna go with a trail rig I should try to get my old mans 79 and have that be a project instead of having to go through so much on the 88? I have thought about buying it from him cause its an awesome truck I just didnt think it would be good for wheeling because of how big it is. But that is a hell of an idea. Make my 88 the raft transport for trips to the river and convert the 79 into a straight trail rig. hmmmm
Re: Project 88
After enough trips on the trail they will be the same width.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
Re: Project 88
Hmmm now my brain is spinning. I weighed pro's and cons to having two trucks and I think I may take the front end from my dads truck before he sells it that way I have that going for me because right now it has a vacuum leak, a tranny leak, the steering box(I think) stopped working and it barely stays running. Although that does make it seem like a perfect truck for a trail rig...
Re: Project 88
Originally posted by Big_Chris_75 View PostHmmm now my brain is spinning. I weighed pro's and cons to having two trucks and I think I may take the front end from my dads truck before he sells it that way I have that going for me because right now it has a vacuum leak, a tranny leak, the steering box(I think) stopped working and it barely stays running. Although that does make it seem like a perfect truck for a trail rig...
my $.02
FungussigpicRoad trips on an island get boring after the 1st lap...
