Alrighty fellas... I figured I better start this thread to keep up my motivation and search for advice on the many questions I'm sure I'll have. Pics will be coming in the near future (2.5 month old twins allowing...).
Here's the low down:
I've got a 1969 Bronco I bought on July 4, 2004 in Reno, NV. It was pretty much bone stock with a straight, fairly rust free body. You can see the mods that have been done since then in my signature.
The goal here is to make a very reliable rig that is Rubicon worthy but I don't plan on beating it against the rocks (too bad) and I have no problem taking bypasses from time to time to salvage the body...
Mods I'm working on now:
I've got a '69 302 with about 15K on a rebuild that a friend GAVE me. I'm currently swapping this in as the original 302 is pretty tired. I've resealed and repainted it and am going with a Q-jet carb on an Edlebrock performer intake. I'll be pulling the Pertronix ignition off the original as well as the Flowkooler water pump and putting it on the "new" engine. I've got a set of Mustang shorties (that are temp coated) on it as well and know of the clearance issues already. I've got the WCB extreme motor mounts on and am hoping this helps with the downpipe issues on the passenger side a bit. As far as the driver's side... I noticed the header runs right into the stock clutch linkage so I'll be going with a Wilwood hyd clutch setup from Summit (thanks to those who've already given me the steer on this one!). 2 into 1 exhaust will go on and I'm leaning toward a 2" into 2.5" MagnaFlow...
I rebuilt an NP-435 and have the adapter to the Dana-20 (which is on the bench w/ master rebuild kit sitting next to it).
I'm keeping the stock manual brakes for now, discs in front - drum rear, as they are great on the trail (when the motor floods out w/ the current AFB carb!). And also because "why fix it if it ain't broke"?...
I've got a 3G 130 amp alternator waiting to go on as well that will have a BC 1 wire regulator and new brushes. This being said, is this a direct bolt on with the original bracketry or do I need a new bracket? I'll be pulling the V-belt pulley off the original alt and putting it on the 3G.
As far as the body goes:
I've got custom rear fenders that work great but I'll be trimming the front corners of the fronts as the 33's catch when flexed. No big deal there. I've also got a pair of WCB extreme rocker gaurds that will be bolted on (won these at the raffle at Bronco Daze last Oct w/ the extreme motor mounts! Thanks Dusty!). Eventually I'll go to 35's when this set of BFG ATs wear out. Not sure that the rear fender treatment I've got will handle 37s...
Now for some questions that are close to reality:
1. I've got the engine bay empty now and am looking to coat or repaint after some serious wire wheel work. What is the skinny on POR-15? If I go this route, what equipment will I need (if any) to apply this stuff or does it come in a complete kit ready to mix and apply? I'd like to repaint the engine bay Ford red like the rest of the rig but am leaning toward the protection of the POR-15. If it only comes in black I think that will be OK or can I color match it to my current paint job?
2. Q-jet plumbing... anyone got any pics of vaccum line routing into a Performer intake? I've got the Pertronix vaccum advanced distributor that will need to be plumbed into it also. And then there's the electric choke which I'll need to wire as well.
3. NP-435 shifter... I'm looking to run the stock "T" shifter on my xfer case. Is it possible to bend the shifter to clear it ok or would anyone recommend replacing the T handle with something more "sleek" to stay out of the way of the 435 shifter? I know I'll have to bend it to clear the dash anyway... Eventually I'll be fabbing up a "gearbanger" type setup but need to get this thing back on the road by June to make Big Bear Bronco Bash down here!
Thanks a ton for any help and encouragement you guys might have! I'll post some pics prior to teardown and hopefully get some up this week of where it sits now with the drivetrain out.
Wish me luck! These twins are kicking my A$$!!!!
Fungus
Fungus
