Here are some pics of my new rig getting built it will have coilovers and bypass shocks on each corner with air bumps,600hp,atlas5.0,hughes powerglide,built out of chromo,with rear steer it should be pretty insane I sold my red bronco last week so now this one should come together alot quicker
buggy with bronco skins
That thing is gonna bet nuts!1970 w/89 5.0, np 435/203/205, 456/locker/ARB, 4 wheel disc brakes w/hydroboost, 5.5" lift w/ext.radius arms, 3" bod lift, RS 9000's, tilt column, Hydro assist steering, 39.5" pitbull's on H1's. 4 link rear suspension. Hey brother, can you spare some change, I need parts....
bronco buggy
The bronco is getting built at 530 racing in placerville and is built from scratch this bronco is a little different from my older one it has more detail in getting built it will have dimple dye holes all over it to make it look good the 2.5 coilovers are going to be mounted on my links and the 2.5 bypass shocks will be mounted on the axles and the skins will be able to come off and it will have a automatic tranny instead of a manual and over twice the horse power I will kinda be a dual purpose rig I will be able to haul ass and jump it if I want or I will be able to crawl it my old rig was set up for crawling only and you couldn't haul ass in it at pismo so this should be much better
Wow... That is a hell of a lot of tube!
This will be a cool build to watch come together. Keep the pix coming.1970 Bronco
LOL Matt!
I thought you sold the Red one to get something more street-able.
Guess not!
Your going to run a Coil over AND a bypass shock on each wheel?
Whats the thinking, to valve the CO soft, just to aid the Bypass shock?Mark Harris
Guess not!
Originally posted by Rockbronco67 View PostAny updates?Last edited by maui matt; 06-25-2008, 10:39 AM.
