Well I got my 60s the front is a 1979 Ford HP King Pin, the rear is a 1998 Dodge. Plans are to fill both with 5.13 gears,and 1350 yokes the front will have an ARB will need new rotors calipers and King Pins. TRO the steering Rod ends or Tie rods ?( what do you think) Heavy duty Dif. cover, Cage weld on. http://www.cageoffroad.com/product_d...=266&itemid=75
The rear will get a 35 spline Detroit Locker with Compleat Off Road 35 spline axles. Should not have to bore the tubes out a Dana 70 35 spline axle will slide in and my bore is bigger than the 70. And Dic Brakes http://www.tsmmfg.com/ If any one has better ideas please let me know
Brian
Reason for Editing:
SELLING the 86 Dana going with a 1979 Dana 60.
Brian
Reason for Editing:
