So this all started with me wanting to upgrade my bronco combined with the opportunity to buy Matts old rig. The idea was to strip my yellow Bronco of the engine, drivetrain, axles and tires and swap them over to the blue one.
Project Rock-Crawler
67 Camaro Lq4,built 200r4,Hotchkis suspension(work in progre$$)Tags: None
Re: Project Rock-Crawler
First order of business was to cut all the brackets off the front 60 and straighten the axle. It's been bent since I've had it and leaks oil because the axle shaft is not centered on the inner oil seal. I called around and couldn't find a shop that really wanted to do it. I came across an I beam being tossed from a job and snagged it. Using some chain, jacks and heat, I jacked up the center section till it was past straight in the opposite direction. I let it cool on its own then welded in an Artec truss.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
I was just looking at all the pics and had to stop and look at the second picture with your body on the trailer. Holy F%$^ are you trying to kill yourself. Your jack with the leaning blocks and the front end on a cart with castors. LOL. Good progress. Moving right alongLast edited by Rockbronco67; 08-28-2017, 08:00 AM.
I'm sure you were wondering, yes it did fall.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
