Time I actually posted a little about what I have been building. What seems like forever ago I bought a Trent fab starter chassis to build a buggy. Nice piece. While I was waiting forever for them to get me my piece I disassembled my 72 that I had been wheeling for around 14 years. I cut down the frame to be about three feet long, keeping the rear suspension mounts and enough frame to mount my radius arms right into the end of the frame. Still has the vin on the frame. This gives me a 108" WB. I then set the engine trany and t-case in 9" back from where it originally was and reinstalled the original crossmember. 17 weeks later the starter chassis showed up and I married the two together. I then proceeded to add a ton of tubing to fill out the chassis. When that was done I built a floor structure out of 1" sq tubing, and skinned it with aluminum. As of late I have mounted the drivers seat/harness, hung the pedals and master cylinder. Getting down to a short list to get it running. Have plans to go to Moab in October. Specs are 302/435/20 9" and 44. 36" iroks and ORI's
Earlybronco72's slow project
Re: Earlybronco72's slow project
After all this time we only get one pic? And you make me turn my head . Looks good.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
Are you still going to be able to pull the front locker and ring gear out(if you need to) with that ram mount there? Looks pretty tight...SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Originally posted by Efibroncoman View PostAre you still going to be able to pull the front locker and ring gear out(if you need to) with that ram mount there? Looks pretty tight...Marc D.
It's nice to have the option to use part of your frame for the rear suspension. Kind of like a Hendrix chassis for a toyota.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
