Well thought I would share some pics. I just finished getting all the electrical accessories wired on a seperate fuse panel, cleaned up the original wiring, down to stock with no extras, cleaned and set-up the dash and finally was able to mount the cage and get it rolling. Still have alot to do, bumpers, output shaft,front end narrowing, blah, blah, blah. But I think she is about done for the next several months.
72 EB Build-up
That's my cage. The rig had a very simple 4 point when I bought it and I built it out to what I desired. It has been a real learning process. I am looking forward to helping some friends build/modify theirs. Thanks FM72EB, one-ton fab project that will never end
Originally posted by FamilymanWiring pics - dual batteries and accessory wiring panel (its mounted between the center tubes in the front section of they cage for easy access even when restained). If you haven't tried the GM Weather paks for your wiring you should they work great, but they are a little pricey“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
Originally posted by FamilymanThat's my cage. The rig had a very simple 4 point when I bought it and I built it out to what I desired. It has been a real learning process. I am looking forward to helping some friends build/modify theirs. Thanks FM
That's awesome that you did it yourself. It looks awesome! No better feeling in the world than to stand back and say, "yeah, I made that". I need to build me a family style cage pretty soon. Where are you located? I'd love to check yours out. Do you have a bender?
Where are you located? I'd love to check yours out. Do you have a bender?72EB, one-ton fab project that will never end
