A bunch of Broncos from the CA Bronco Yahoo! Group will be at Hollister Hills this Sunday 5/23. Details not nailed down yet but we will likely meet at the obstacle course area mid to late morning.
Hollister Hills 5/23/10
Re: Hollister Hills 5/23/10
Thinking about it. I have no front gears but I know the park is doable in 2wd. Just depends on the boat bun this weekend.{o===o}Originally posted by TBS-POPSEXCUSSSSSSE ME oh RUBIMASTER!!! I forgot how Awesome YOU ARE!!! I BEG your forgivness....Originally posted by CityHickI don't give probabilities in percentage format anymore
I only took a few pics. It was a good day. We played around in the obsticle course for a while, then I tried the mini Rubicon. I did OK with help from Gil and Nate. I got hung up in this one section, I guess I need bigger tiresI pulled off after about 40 feet because I was taking so long and the rocks got bigger... We then went to the quarry, then to to top for lunch. We finished off at the new obsticle course.
Kyle
Aptos
1967 EB, 5.8, AOD, Stak 5.22, 37's, Dana44/9" w/ARBs 5.13s, 3.5" WH SL, 2" BL, 4wheel disc hydroboost, wristed.
The Bronco did great. I was very happy with the recent mods. The Stak was pretty easy to shift and I enjoyed the lower 5:1 low gear for technical spots. At the end of the day I used my new OBA to air up and it took longer than I thought it would. I might add a cable throttle that Nate used to raise his idle. He used a 3 speed bicycle shifter connected to choke cable.Kyle
Aptos
Some Broncos came with a cable throttle knob on the dash. Mine did and I use it to bump up my idle when running the compressor. it works like a champ and it looks factory, because it is...1970 Bronco
What is the "new" obstacle course.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
The new obs course is fun to play around on. It is all geared toward like 35 inch tires. I could see having a fun day of time trails around it!
