Last week I switched to a 97 Mustang H/B. I also sent the H/B unit off to Vanco to be high flowed. Ran it all last weekend and all was fine, went to go play today and the front brakes started dragging.
This is a 4 wheel disk set up with a . Remanufactured - Brake Master Cylinder I also removed the Proportioning Valve out of the system for it was leaking
The push rod slides right on the brake pedal nice and easy so it not pushing on the H/B. Any thoughts as to what could be wrong. Find it hard that 2 calipers started sticking all at once
