I finally did it. Not really needing more but wanting more I found a complete 351W roller donor to replace the 88 5.0 thats currently in my Bronco. Then, as luck would have it... I found another roller short block on a trade. The complete engine was in a 97 F250. When I got under the truck to losen the engine mount I noticed the Ford Reman tag from 2002. This block looks a little rough on the outside, lots of rust, probably because at one time it was a CalTrans truck but the coolant and oil looked great. The other block is really clean, other than some rust in 3 cylinders from sitting without heads. I think I will be able to get away with only going .010", just depends on what block I decide to use. This will be an over time build to keep the spending spike down, unless of course I decide to ask forgiveness instead of permission.
For my build I kind of want BIG CI. However, there is a budget so if it remains a 351 I am ok with that too. Main goal, more power and want this engine to be just as reliable as the somewhat tired 5.0 that powers the Bronco now. It will remain EFI, but I dont want to have to do huge injectors, big mass air and TB, tons of ECU work. I want to keep it pretty simple, most bang for the buck type of build.
So now for the Tech... thats where you guys with 351 knowledge come in.
To stroke or not to stroke, cam, heads, etc, etc, etc.
