I noticed that I am not getting full throttle in the carb when I press the gas pedal all the way down. Anyone upgrade to a throttle cabel setup they like? Or has anyone replaced the stock rod connecting the carb to the pedal assembly with an adjustable set up?
Throttle linkage Options
Re: Throttle linkage Options
yup i had the BC broncos cable on mine loved it.. 20.00 to your door..Originally posted by buknbronco View PostI noticed that I am not getting full throttle in the carb when I press the gas pedal all the way down. Anyone upgrade to a throttle cabel setup they like? Or has anyone replaced the stock rod connecting the carb to the pedal assembly with an adjustable set up?
http://www.bcbroncos.com/store/produ...oducts_id=1814Last edited by Daddy4zack; 08-17-2011, 07:21 AM.KK6DAD
What Im running.
http://www.lokar.com/product-pgs/thr...le-cables.html
It is a cut to fit if you want a short, to the point, cable setup. I ran it for years before I decided to cut it to about 9"{o===o}Originally posted by TBS-POPSEXCUSSSSSSE ME oh RUBIMASTER!!! I forgot how Awesome YOU ARE!!! I BEG your forgivness....
Originally posted by CityHickI don't give probabilities in percentage format anymore
I replaced the link from the stock throttle linkage bell crank, out to the carburetor with a piece of all thread and two heim joints. I was able to adjust it to match the throw of my throttle venturi and it works like a champ. Cheap too.1970 Bronco
What setup do you have now that's not working? Stock would open up all the way if it was adjusted properly or not all floppy.
Well, they were pretty floppy even from the factory, but they would still pull a blade all the way open.
Just curious. I happen to like cables and all-thread options. Just wondering what's wrong currently.
PaulWild Horses 4-Wheel Drive
I've got a 4 brl edelcock sitting on top of a 1 inc spacer. The rod that pushes the throttle is bent pretty far out of shape, which is part of the problem(custom adjustment job done years ago). So when working on it the other day I noticed I was'nt getting full throttle when the gas petttel was pushed down. So since the rod is bent anyways I was looking for a better and cleaner set up then I have now.302, edelbrock heads, roller rockers, intake, sanderson shorty headers,
69 bronco
