No Patrick, I didn't repaint it, well actually I did, but that isn't what this is about. I finally decided to move the front axle forward after 6 years of thinking about it. I will be using a set of Duff arms, a f-150 box for the steering, and ballistic fab coil buckets. I will need to build the frame mounts for the arms since they were used and didn't come with the frame brackets. Anyone happen to have a good picture of the frame brackets? I'm about to head out and remove everything from the frame.
I got board
Re: I got board
Originally posted by Rockbronco67 View PostOnce you get this done you should try little sluice again and make sure I am there to watch again.Marc D.
Re: I got board
Those little Dual 4ft florescent lights are cheap everywhere and just use a 3 prong plug. I wired up 4 of them in my garage and they made a huge difference. But more space would always be nice too! Ballistic make some really nice brackets that would work great for radius arm mounts, I don't know if they would be the right size for the heims on your arms.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Re: I got board
I too bought my Cage arms used. Cage sold me a pair of their frame brackets, I don't remember the price but it wasn't terrible. Would be easy enough to fabricate a set though. They are little more than some 3/16 or 1/4" tabs welded and bolted to each side of the frame, protruding down about 4" with a truss running between them that gets tacked to the frame as well. Think of a big "H" with the upper half cradling the frame and the lower half hanging down to support those big ol heims.1970 Bronco
Re: I got board
Originally posted by CityHick View PostI too bought my Cage arms used. Cage sold me a pair of their frame brackets, I don't remember the price but it wasn't terrible. Would be easy enough to fabricate a set though. They are little more than some 3/16 or 1/4" tabs welded and bolted to each side of the frame, protruding down about 4" with a truss running between them that gets tacked to the frame as well. Think of a big "H" with the upper half cradling the frame and the lower half hanging down to support those big ol heims.
Originally posted by Efibroncoman View PostThose little Dual 4ft florescent lights are cheap everywhere and just use a 3 prong plug. I wired up 4 of them in my garage and they made a huge difference. But more space would always be nice too! Ballistic make some really nice brackets that would work great for radius arm mounts, I don't know if they would be the right size for the heims on your arms.
Originally posted by BRONKEN View PostO.T. must be slow this week.
We are however replacing about 20,000ft of 20 year old 750 aluminum with 1000kcml copper in an express run out of one our subs. It's a bunch of crap we have had laying around in our yard for six years and they want to get rid of it. They have found that 1000kcml ocanite alum will pack more amps. I sure would rather be replacing some old nasty power poles though.Marc D.
Re: I got board
Maybe yoo can get the scrap wire That should be enough to put new axles under rig too.69, 7" lift,D-44 with air locker, 9" 35 spl full floater with a locker, 4-wheel disc, custom paint, one off custom mods, Hanson bumpers and side protection, 35's on Champion beadlocks.
Re: I got board
There are spacers that center the heim between the brackets. Heims are supposed to be used with spacers anyway. I've got to have a picture around somewhere...1970 Bronco
Re: I got board
Originally posted by earlybronco72 View PostNo Patrick, I didn't repaint it, well actually I did, but that isn't what this is about. I finally decided to move the front axle forward after 6 years of thinking about it. I will be using a set of Duff arms, a f-150 box for the steering, and ballistic fab coil buckets. I will need to build the frame mounts for the arms since they were used and didn't come with the frame brackets. Anyone happen to have a good picture of the frame brackets? I'm about to head out and remove everything from the frame.
Re: I got board
Originally posted by TRAILBOUND View Postalso start rethinking front body mounts
Originally posted by crawlin68 View PostLOL!! That IS exactly what I thought when I saw the title of your thread. How far forward are you going to go?Marc D.
