OK, so re-thinking this whole EFI thing for my stock 302 when I rebuild it (prob 20 yrs from now!).
With the abundance of "clunkers" in the yards right now I figure its a good time to start collecting some parts once I get my rig on the road in the next couple weeks!...
As far as the '96-'01 Exploders, I've got upper/ lower intakes, throttle body, fuel rail w/ driver's side return, regulator, 19#/hr injectors, MAF housing & sensor. Anything else I want off this rig as far as EFI goes?
I plan on snagging everything else from an '89-'93 Mustang: Computer (does it matter if it's a manual or auto tranny if I plan on running a VSS?), distributor, coil, throttle cable.
What sensors will I want to pull off either of these donors? VSS, TPS (FFI says Mustang here), ECT, ACT? FFI also says the VSS will work on the D-20 with stock speedo gear and a speedo cable from an Early '80s FSB w/ cruise control?
Any other "junkyard" parts that are recommended or usable?
I've already got the Carter 4070 fuel pump that I can recycle into the EFI system and will just need a hi-press pump to add on.
When the old motor gets a re-work with upgrades I plan to put '69 351W heads on as well as the EFI. I'll re-wire the whole rig w/ an aftermarket harness (not sure but prob Centech or Painless) and go w/ the RJM EFI harness. Does either of the chassis harnesses work better than the other w/ the RJM harness or they all basically the same as far as compatibility?
Thanks for any help from all you EFI gurus!
