I am getting ready to run a metallic fuel line from the mechanical fuel pump up to my stock 2 BBL factory 302. my questions:
1) Where does vapor lock occur? Does it occur in the engine compartment due to heat or does it happen further back towards the tank?
2) Is it a good idea to try and insulate the fuel line from the pump up to the carb to prevent engine heat from heating the fuel?
3) What is the best type of fuel filter to use? Stock filter screws into the carb body type vs. an aftermarket in-line?
4) How do you solve vapor lock? How do you know you have it?
