9" pumpkin?
  • 9" pumpkin?
    OK, Just wondering if 1 case is better then another? not talking about n cases or after market. I have 4-2 in Broncos and 2 on the floor. all 4 are different and was wondering if 1 is better then the other or just bite the bullet and buy an after market case? Looking to build a 4:88 Detroit 31 spline.
    Thanks Jack
    73 Bronco 302 C4 3 1/2 2" 5.14 9"/d44 d20 37"
    Re: 9" pumpkin?
    Some cases depending on model had different ribbing.
    http://www.maliburacing.com/ford_9_i..._nine_inch.htm
      Re: 9" pumpkin?
      Wow, that is a lot of 9" information. According the that website the solid spacer is for Daytona Pinion support set-up.....So that must be why the spacer was too big for my standard pinion support. Good to know.
        Re: 9" pumpkin?
        Na, thats wrong.
        I have used many solid spacers in normal setups.
        Either that or a new one was made 5+ years ago.
          Re: 9" pumpkin?
          [QUOTE=welndmn;58347]Some cases depending on model had different ribbing.
          Thanks, Found that site after I posted. Seems there 2 + the N case. I think I will look for an after market.
          Thanks again.
          Jack
            Re: 9" pumpkin?
            Originally posted by welndmn View Post
            Na, thats wrong.
            Cool. That's what I'll get
            1970 w/89 5.0, np 435/203/205, 456/locker/ARB, 4 wheel disc brakes w/hydroboost, 5.5" lift w/ext.radius arms, 3" bod lift, RS 9000's, tilt column, Hydro assist steering, 39.5" pitbull's on H1's. 4 link rear suspension. Hey brother, can you spare some change, I need parts....
