This weekend's project was to wire a bunch of my accessories to relays, including the headlights. Now that I've got my headlights drawing power via big relays straight off the battery (via my under hood auxiliary fuse box with overkill BIG wires), I want to run higher power headlights.
Running through the relays, I gained over 1/2 volt at the headlight connector, and while that does not sound like much, it made a noticeable difference in the light output from my existing headlights - but now that my headlight switch is only triggering my relays, it won't fry when I connect up some higer-wattage bulbs.
SO.... Here's a question to the masses: Without spending an arm and a leg on the H4 headlights that some of the vendors sell - what are the best replacement headlights you can buy off the shelf? I am looking for the brightest (street legal) headlights that I can run. I have no doubt my upgraded wiring can handle whatever bulb I can fit in the stock grill...
TIA
-Tony
TIA
-Tony
