Hey All. As some know I recently took delivery of a set of US Mags Indy U101 wheels in 17x9, and had new 37" tires installed onto them. The other day while lowering the tire pressures from the 40psi set by the shop who did the installation, I discovered that there were some cracks/bulges forming on the inside surface of the hub bore. Concerned by this, I reported the problem to the Amazon seller who I got the wheels from, and he pursued the issue with the manufacturer.
Long story short, I caused this problem by torquing the lug nuts to 100 ft-lbs as I'd always done with my previous steel wheels and with most/all OEM wheels on my other vehicles.
As stated the Amazon seller took my concern to the US Mags company, who agreed to cover the wheels, despite their stance that this was my mistake under their warranty. This was a relief, and the vendor then told me that I cannot follow OEM specs with these wheels, and that they should be torqued only to 60 ft-lbs max. Maybe I'm the only dumbass who did not know this, but in case I'm not... learn from my mistake!
I have since learned that OEM aluminum wheels (and some aftermarket aluminum wheels) have steel inserts in the lug holes which allow the higher OEM torque spec. "cheaper" wheels without said reinforcement will crush under that much force.
I am glad that I noticed this problem before it resulted in a catastrophic failure on the road. Having already experienced a high speed wheel bearing failure, I am a little sensitive to the idea of losing a wheel at speed... in both of these situations I feel that someone was looking out for me.
