Hello all, I'm contemplating doing an Explorer EFI swap on the current motor in my Bronco, however I'd like to get a clear picture of what that entails before I take the initial plunge.
My current motor is a 302, flat tappet, 15426378 firing order, recently rebuilt. No mechanical issues, currently running stock exhaust manifolds, and an Autolite 2100 carb. Heads are stock.302 heads. Running a Saginaw power steering pump with remote reservoir, stock alternator, fixed blade fan.
I found a 1996 Ford Explorer donor vehicle that I can get for cheap. Only thing wrong with it according to the owner is a bad fuel pump. Current mileage is about 200,000. I went and looked at it today and took a photo of the intake (attached below).
So, here come the questions. If any of you know of previous discussions which address these questions (and the conversion process in general), feel free to link to those discussions.
1. Would I need to use the heads from the Explorer motor, or can I bolt the intake from the Explorer directly on my existing heads (and would this be a bad idea)? I believe (based on the year) the Explorer has GT40 heads.
2. I understand I would need to change the front cover out for the crankshaft pickup. Would I need to convert to the serpentine belt setup, and could I adapt my existing Saginaw pump?
3. Does the camshaft need to be changed to change my firing order?
4. What resources are available online for making the ECU wiring harness?
5. What else would I need to purchase to make this work?
6. How would this setup perform on the trail?
7. Is it worth it opening this can of worms?
As far as why I'm thinking of doing this, it is primarily for drivability issues. I've been looking at different EFI options out there for years now, and although this seems to be the cheapest option, it also looks to have a lot of fitment and compatibility concerns.
Any help is greatly appreciated, thanks in advance!
Clint
Clint
