Alright I just started looking into installing full width axles into my bronco. I want to put in fulll width dana 44 and 9 inch, but I wasn't sure what year truck/broncos to look for. What are the most common year truck/ bronco that you need to look for ? I was also wondering what needs to be done on the front axle regarding radius arms and steering? Thanks guys.
full width axles?
try to find a 77 f150 4x4. I think that is the only year that had welded cs, the good 9 inch and front disks. That year could also have granny low NP435/ NP205 and a nice power steering box and maybe even a tilt column. The rear springs are nice. And the drivelines might be useable.
I originally had all that stuff under my early bronco. I wish I would have just left it alone at that point.69 bronco, 72 bronco, 66 vert stang
I believe the d44 prior to the 78 and 79 f150 and broncos had thicker tubes as well. I ran one out of a 73 f100 with cheby disk brakes, also you dont have to worry about not being able to move the wedges like the 78-79. Im also pretty sure all D44 c`s were welded on until 1978. good luck bro
JRLast edited by RockJock72; 12-03-2007, 04:26 PM.Bad guy, good guy, I`m the guy with the gun...
See post on the black beast. we just bought that to do the same thing. paid $500 for a 78 big bronco and it has HP d44 /9'' ...Last edited by TBS-POPS; 12-03-2007, 04:59 PM.72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
'76 has the weld-on wedges as well. That makes it a piece of cake to just grind them off and move them in. If you end up with a 78/79 with cast wedges, you can move the coil buckets outboard, that's not too hard either. We have rigs at the shop that have been done both ways.
Dusty
I used the 76 f150 for the welded "c" and disc brakes. It also has .500 thick tubes. by moving the Cs in a couple inches it gives you clearance on the radius arms to run bigger tires. I have seen people run the 78/79 cast Cs without moving the spring buckets out without any problems but the coils end up looking kinda like / \ . RD
You will buy or use the old tie rod that came with the HP44.
You will have to buy a new drag link.
If you don't have it allready doing the full width is the perfect time to upgrade to the Chevy steering.Mark Harris
