First let me start off by saying the PO did all the wiring mess on this thing and am slowly trying to fix the problems as I go.
The first is while the truck is off the factory ignition box on the fire wall has a constant draw of 1.7 amps on the wire that comes from the positive side of the starter relay. This only started after I had a small fire that shorted that wire along with others out because unknown to me there were two bare wires hanging from the alternator wire.
The box is wired like so: One wire comes from the starter relay to power up the box it seems, one goes to the choke from the box, anothr goes from the box to the ignition switch, another goes to a condenser looking deal that mounts to the box. So I am thinking that fire shorted the box out and killed it so now there is a constant draw.
What does this box really do???????
NEXT
I put in an Accel points eliminator (#2020) and Accel coil (#8140C). For some reason the coil keeps getting very hot and either boiling the oil out or shuts the engine off completely. I have tried three new coils at this point with the same result.
What I do know: The positive side of the coil sees 11.7v when the key is on (the wire goes directly to the ignition switch) when running the positive sees anwhere from 11.7v-13v maybie 14v. But the negative side of the coil sees 1.3v with the key on and 5.4 to 7.5v when running. (I am thinking this is why it is getting so hot)
Thanks,
Terry
NEXT
Thanks,
Terry
