I've got them on my D44. And I haven't had a single problem with them! Although my Bronco hasn't left my driveway yet. My drivers side knuckle was machined, drilled and tapped from the factory so I had the passenger side knuckle done at Parts Mikes shop. I also got my high steer arms from him. So far everything looks good, but I still need to go test it on the trails.
What did you get your knuckles off of? Will any chevy D44 knuckle work?
I have a Ford full width 3/4 ton heavy duty HP D44 and it came with flat top knuckles. I don't see why the Chevy flat tops wouldn't work though. They should bolt right on any D44.
