LED headlights with DRL
Re: LED headlights with DRL
Personally, I would run a relay triggered by a circuit that is hot in run only, and power the DRLs right off the battery via that relay. It should be easy enough to find a circuit that is hot in run.
I am curious about which headlights you ordered - can you share a link? I have just about had it with my halogens, I cannot find a bulb that is bright enough on the low setting, my highs are blindingly bright but the lows just suck...1970 Bronco
