So my old worn 302 always had to be cranked for a while after it sat overnight before it would start. I always attributed it to the low compression and blown rings. That block ended up being junk and i installed a 5.0 roller motor from a mercury mountaineer. Unfortunately the long crank when cold issue still persists. I installed a new fuel pump with the new motor, but the fuel lines and carb are all the same. Its the stock tank with a 4 barrel quadrajet. Can the fuel be draining back into the tank? Or is the fuel evaporating from the carb? Any ideas on how to fix something like this?
Fuel Drain back
