Guess I need to prove the stock Bronco could keep up (or pass acouple of times) with thjeep I was running with. He had ARB F/R and atlas.
What's the chances I started breaking splindes off the axle shaft? I seem to remember with rear up you can turn the tire and te other would spin oppisite instantly. Now I have to spin te pass side 1/4 turn before it catches and spins te drive line. The driver side is solid and engauges instantly. I thought my ebrake was hanging up but now I'm worried I have broken splinds floating around in te rear end. Should I pull the shaft to inspect? Or is there another way to check
