My Sanden compressor literally went up in smoke after completing the Rubicon trip and airing my 4 tires and two of my buddy's tires at the Tahoe staging area.
I have been using that very Sanden compressor with the "grease mod" that I've discussed on this forum before. 5 years of service. I run a 2.5 gallon tank under the body which then runs my air lockers through a pressure regulated tank outlet. Then of course its also on the hook for tire inflation duties post-trail.
The Sanden works reasonably well though I have never been a fan of sending oil/grease upstream even if using a coalescing filter. I have tried to find a way to mount a York but space is at a premium.
I do not love the idea of repurposing an a/c compressor for onboard air and probably won't run another Sanden compressor. The York at least has an oil reservoir, but friends who run them still get some oil upstream even with the oil passage modification that many here have done.
I am looking for new ideas... does anybody know of a viable belt driven alternative? I run a serpentine belt - would love to run some kind of purpose-built compressor (big rig style maybe... just a wild idea).
I've also been looking at the pumps from ARB and ViAir. Pricey but some deliver fairly respectable CFM+PSI. I don't necessarily need to run air tools but like to know I can air up my 37" tires from 15 to 25-30psi without spending all day at it.
In any case I may run a dedicated ARB compressor for my lockers and a second for tire filling, or perhaps a redundant system. Looking for relatively high duty cycle, reliability, and simplicity.
Any suggestions, part numbers, and links are appreciated. I am open to many alternatives... looking to improve upon what I have rather than replace with like kind.
Thanks in advance!
-Tony
Thanks in advance!
-Tony
