Ok so I'm at a loss....I finally got the assembled HD output shaft and housing from WH and am scratching my head with the speedo install. I'm running Ford fuel injection with a stock speedo cable and Autometer speedometer as well as the ford VSS.
The complete kit comes with the output shaft/housing, Atlas speed cable, speedo gear, and Atlas speedo housing assembly. Now this is by no means a bash on WH, but the instructions in the box by AA and the one online are sparse at best and do not show how to adapt the housing assembly to the Ford VSS. Nor does it show how to assemble said housing. What am I missing either parts wise or common sense? (Not exactly plug and play on the speedo side of things, haven't started the housing install yet.......)
Thanks
Sean
Thanks
Sean
