Ok so they're not really bushings - but on OEM Ford (serpentine) accessory brackets there are those split steel spacers/bushings/whatever where you run the bolts through. Does anybody know where to get those? I suppose junk yards could be a source but they tend to be stuck in there pretty tight.
For some reason I removed one or two of those in the past and I can't find the ones I removed nor replacement pieces. Maybe I'm searching with the wrong terms. I run a Mustang 5.0 alternator bracket and I am missing the one that goes in the upper alternator bolt hole in that bracket. I have an accessory squeak and that missing piece seems to be at least one culprit - the bolt isn't tight in that hole (though with the belt on, it doesn't move).
I swear I cause more problems than I fix sometimes... trying to overcome my current level of Bronco burn-out and just get it back to some semblance of "normal".
Anybody???
Anybody???
