my 302 ran before i pulled the pan to replace the rear main seal. i had to prime the oil pump and re stab the dizzy before trying to start it. i have spark and gas but it backfires through carb and wont turn over. i made sure it was tdc by puling the plug and putting a wire in the #1 piston and i lined up the rotor at #1. still nothing. i even swapped the wires 180 on the dizzy with the same result.
302 wont start
Re: 302 wont start
I wish i had a buck for every time i did the timing or firing order wrong. go back to square one, tdc reset the dizzy, redo the firing order for your motor. non ho 15426378-
If it doesn't start first pop, have someone turn it over while you slowly rotate the dizzy advanced and retarded and if you stabbed it correctly you'll find the firing point.“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
Re: 302 wont start
Originally posted by jperry1290 View PostIt runs now, but only if dizzy is all the way advanced. I'm guessing one tooth off unless anyone has any other ideas“I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it.” TJ
Re: 302 wont start
8*btdc72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
Re: 302 wont start
Originally posted by TRAILBOUND View Post19* is way way to much, IIRC stock is 8-10* and for a little bump maybe up it to 12*. The late model guys that are concerned with daily driving and squeezing every last drop of fuel out it run 16* with a modified ignition system.Marc D.
