I have tried two different sets of headers and all have fitment issues. What are you guys running with a 351/3550/D20 combo that fit using the stock clutch stuff.
What headers are you running 351/3550 combo
Re: What headers are you running 351/3550 combo
what ones did you use ??
http://www.summitracing.com/search/b...gger%20headersOriginally posted by TBS-POPSAfter a huge amount of reflection, I have determined that what I saw in ukiah was in fact Brians bronco. I was also informed by my wife that she infact heard it run!!
Originally posted by Bronco Brian View PostSOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
I have the toms broncos headers and another unknown name header that both don't fit. The passenger side hits the frame at the trans cross member. The drivers side runs into the clutch linkage making it impossible to get up into place to check for fitment. I removed the clutch equalizer bar and still can't get the header into place.
So you have long tube headers?
It's best to swap to shorties, shorties almost always fit, long tubes crash into things when you're not stock.Mark Harris
I have WH shorties on my 5.8. They come close to the shock and spring mount on the pass side. Took an hour to install. Driver side was easy. If you cut out the inner fenders it isn't too bad. I have a C4 with a Cold Duck.
I run the block huggers on my 71 with a 351/435/Atlas. I also have the extreme motor mounts. Its tight, but they fit without any modifications.
Thinking about trying the block huggers with my 351 and ZF ThoughtsOriginally posted by TBS-POPSAfter a huge amount of reflection, I have determined that what I saw in ukiah was in fact Brians bronco. I was also informed by my wife that she infact heard it run!!
