I need to remove a standard oil pressure sending unit (see pic). I have no tools here and need to know what size socket to buy/borrow.
What size socket??
Re: What size socket??
I knew that friend. I was just hoping to find out what size I need. I would rather not drive the flatbed to the shop until I get another read on this oil pressure issue. Suppose I could just borrow 13/16 to say 1 1/8. I can hardly see the sender.Just a stock 1966 U13, 170 ci 6 cyl, no kiddin'.
Uh that's an idiot light sender, not a gauge one! The one for an oil pressure gauge is much larger, and has a domed end, and needs an open end wrench to remove. And those are mounted on an extension, not directly into the block.
The socket for the idiot light sender is a special one with rounded corners, not a regular six or twelve pointer. JL'66 roadster, 200 six, GM HEI, 3.03/Jeep T150 shifter, 4.11 gears, 3" lift, 33X12.5
"I can explain it to you a hundred times, but I can't understand it for you!"
Some ebay links, and item numbers if the links don't work:
Sender for gauge:
http://www.ebay.com/itm/OIL-GAUGE-PR...098c0c&vxp=mtr
Item 230821563404
Extension for gauge sender:
http://www.ebay.com/itm/1965-66-Must...r#ht_500wt_971
Item 360460631718
Special socket for idiot light sender:
http://www.ebay.com/itm/Snap-On-3-8-...r#ht_500wt_971
Item 221071741845
It says the socket is 1 inch, but note the rounded "flats". JL'66 roadster, 200 six, GM HEI, 3.03/Jeep T150 shifter, 4.11 gears, 3" lift, 33X12.5
Better yet Every Kragen auto parts store has the Lisle Switch sockets in stock.... And they're cheap!SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Same metric crescent wrench I've got!
Good tip on the special socket - I think that's where I got mine about 30 years ago. lol. JL'66 roadster, 200 six, GM HEI, 3.03/Jeep T150 shifter, 4.11 gears, 3" lift, 33X12.5
Originally posted by Henry66 View PostI need to remove a standard oil pressure sending unit (see pic). I have no tools here and need to know what size socket to buy/borrow.Originally posted by Efibroncoman View PostBetter yet Every Kragen auto parts store has the Lisle Switch sockets in stock.... And they're cheap!Originally posted by TBS-POPSAfter a huge amount of reflection, I have determined that what I saw in ukiah was in fact Brians bronco. I was also informed by my wife that she infact heard it run!!
Henry, I have one you can borrow... Drive to Palo Alto/Stanford to pick it up, this Thursday or Saturday
Mac tools SC43 and/or SC46 one of them will work....
Doug2002 F250 Superduty, 7.3 241,500 miles and counting
Or if you wanted to come by some time to look at that air cleaner, I probably have a socket that would work too.
We can even verify by grabbing a sender from Winchester Auto if we needed to.
PaulWild Horses 4-Wheel Drive
The really good news is the new gauge read 70 lbs on start up and 60 hot. The bad news is I failed to plumb the line and it got burned on exhaust, my arms are scratched up and burnt a little, and at one time my hand was actually stuck between engine and fire wall. And oh yeah, four trips to the parts store. On getting ready to take a shower I saw this (which I wore on the last parts trip). No wonder the guys were so nice.Just a stock 1966 U13, 170 ci 6 cyl, no kiddin'.
