Do I need to run one?? Tell me what you think. 302 with Edlebrock fuel injection.
PCV Valve
Re: PCV Valve
Yes if you are running any type of vacuum crankcase vent system.. It provides a check valve type of safety in the event of a backfire in the intake system. If your not using vacuum to extract the blowby gases from the crankcase and just have vent caps on the valve covers then no.72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
ALL MY DRINKING BUDDIES HAVE A SEVERE BRONCO PROBLEM !!!
Originally posted by 71BRONCO71BULLSHIT! I love your meat in my mouth
Re: PCV Valve
Uhm...why would you avoid a crankcase ventilator?
The purpose of the PCV valve is to maintain a slight vacuum in the crankcase to scavenge off any blow-by for combustion gasses that leak past the rings. This partially burned air/fuel/oil vapor migrates to the top of the engine, and collects in the valve covers, and the lifter galley.
The PCV valve bleeds off that vapor, and replaces it with fresh, clean air from the thing you call vent-caps.
If you do not have some means of venting the crankcase, it will of course eventually find a way to get out...by pressurizing the crankcase. Ford solved this on the SBF in 1963 by using a road draft tube mounted that funny trianglar shaped boss cast into the rear of the intake. The road draft tube takes the excess air/oil vapor, and directs it down past the transmission on to...the ROAD. It makes a huge mess, and it will lubricate your entire undercarriage.
The PCV valve sucks that excess vapor and pulls air IN from the vent caps. If you do not have a PCV valve, then the piston ring blow by will blow air OUT of the vent caps. That ends up messy.
Ford pulled the air out of the valve cover from 1967-85, then moved the location to the back of the intake manifold in 1986. (back where it started in 1963...)
Every vehicle produced after 1967 has a functioning Crankcase ventilation system. It works, and it has nothing to do with SMOG. Why would you ever remove it?
Re: PCV Valve
Now we get all the info!!! the PCV should be plummed totally seperate from the brake booster line. The pvc system IS bennificial to the engine as Mr. Roney said and will keep things from getting messy. The brake booster should be plummed into full manifold vacumm totally by its self. Maybe a pic of your setup would help us see your choices.72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
Re: PCV Valve
With your set-up,if there is no port on the throttle body...I would recommend a throttle body spacer, with an integral vacuum tap. It would sandwich between your throttle body and the intake manifold. Should be able to get one from the local parts supplier, in the carburetor spacer section.
As mentioned...you want the PCV as far away from the brake booster tap as possible. The PCV is a built in vacuum leak, so your booster will never get full vacuum if it is tapped near the PCV port.
On a separate note...how do you like the ProFlo system? I was thinking of going with that system on my 67 Mustang...
