On a carbed engine with an electric fuel pump, is there any reason why I can't plumb the return line from the regulator back into the feed line from the tank before the pump?
Fuel return lines
Fuel return lines
67 Camaro Lq4,built 200r4,Hotchkis suspension(work in progre$$)Tags: None
Re: Fuel return lines
So if it's only an 8-15 lbs pump it's not enough to worry about back pressure and damaging the pump?67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
Thanks. This is for my camaro. Getting really close to firing it up.67 Bronco blue - LS 6.0, 6l90, & atlas (working on it)
