just wondering if any of you have run into this. I'm building a set of 609s using a mix of factory and aftermarket parts, for the front axle I have a fabricated 9" housing of the 3" variety and factory dana 60 inner Cs which are 3.125 so obviously I won't get a press fit with those parts. Just trying to see what other people have done, the options I see are....
a)I have an alignment bar so just center it all in and buzz it together
b)use 1/16" shim stock or sheetmetal around the tube and use the alignment bar
c)turn some larger tubing in the lathe for a press fit on the I.D. of the axle tube and the O.D. of the inner C
I would have bought the larger tube housing but have no access to a lathe large enough for a complete axle. I will probably end up using option C for piece of mind so the inner C is not relying on the weld to support the vehicle
thoughts or experience???? maybe I haven't thought of another option?
