I used them.
Good:
-They came fast
-Very solid
-They look cool!
Bad:
-They don't match bronco springs very well (I think they are made for jeep springs)
-Even though the picture shows them, they didn't come with the spring retainers, I had to order those separately.
-I ended up building a hybrid system but cutting down the factor buckets and welding them to the adjustable parts of the ballistic mounts. (if you need them I have the spring retainers and the upper part of the mount)
In the end I can't imagine a situation where I would actually want to adjust the height (1 inch at a time), but who knows.... I would say if you can find some of the 1978-1979 bronco/f-150 bolt on mounts and just weld them on you will be better off for a fraction of the cost.
Well worth the $$$ IF, IF you can get them from them. Ballistic doesn't have the best reputation right now....
After I put mine on I decided to change my ride height. Worked really well. Company has gone through some changes, so hopefully they are better with there delivery.
Ballistic only said they went though changes, that's the law when you file bankruptcy and want to continue on with your business. I may be jaded as they owe a friend over 30k, but I'd never buy from them.
Ruff Stuff sells similar things.
Have them installed for the rear 4 link. Have them for the front, not installed yet.
Love them. I can get the height I need and still use the super flexy 3.5" springs with my 39.5's..
The tennis balls still look funny!
